not a Mac: HP Visualize C8000
Postby ClassicHasClass » 15 Aug 2012, 13:22
Picked up a HP Visualize C8000 for a nice price, the last of the HP-UX PA-RISC workstations. This one is well-equipped with a FireGL-UX card (the same as the ATI professional FireGL series), dual-core 1.1GHz PA-8900 CPU and a gig of RAM. I'd have it booted and ready to show, but it does not like my KVM, so I'm going to have to get a mechanical switchbox for it and I need to reinstall HP-UX 11i v1 because the install on the built-in hard disk is b0rk3d (the previous owner apparently moved pieces of it to an NIS server which of course it is no longer connected to, so it can't even start X). Fortunately, I have MCOE and GTCE, so I'll just blast it out and install it from scratch when I get a hot minute.
I have a soft spot for PA-RISC because I had root to a HP 9000-K250 and a Visualize C3750 when I was a programmer/DBA. It's actually a very clean instruction set, surprisingly easy to program for, but HP just couldn't compete in the workstation market and as usual bet wrong on Itanic.
User avatar
ClassicHasClass
Re: not a Mac: HP Visualize C8000
Postby mcdermd » 15 Aug 2012, 15:53
Nice. I used K-class and N-class 9000s at one of my previous jobs. HP-UX was always ... interesting. They used the PA-RISC processor in the later HP3000s also. We used those running MPE XL and IMAGE XL databases.
Classic: Too many to list. See http://www.applefool.com for details.
Modern: 21.5" iMac 3.06GHz Core i3, 15" MacBook Pro 2.4 GHz C2D, 13" MacBook 2.1GHz C2D, XServe Dual 2.0GHz G5
User avatar
mcdermd
Postby ClassicHasClass » 16 Aug 2012, 04:58
I don't mind sam, but I prefer smit. What we really hated was the benighted C compiler: just ANSI compliant enough to be ANSI compliant, but still require bizarre hacks to compile. Part of my consultant work was helping one of the other analysts port software to it. One particularly irritating failure turned out to be a bug in HP's preprocessor.
I was always curious about MPE/iX but never got to play with it.
User avatar
ClassicHasClass
Return to Conquests
Who is online
Users browsing this forum: No registered users and 1 guest
