Local barebones Digital Audio $66 AU
Re: Local barebones Digital Audio $66 AU
Postby LCGuy » 06 Nov 2007, 01:19
You don't have a USB keyboard or mouse? Maybe find an old set from someone's old iMac or something? Even an old iMac keyboard and an iPuck will be enough to get you up and going.
Failing that, nip down to your local PC store and buy a PS/2 -> USB adaptor, i'm assuming that much like me, you have an endless supply of PS/2 keyboards. I'm using a DEC keyboard from 1994, and a MS wireless mouse on the iMac via a PS/2 adaptor, and they both work perfectly.
"Bite off more than you can chew and then chew like all Hell" - Peter Brock
User avatar
LCGuy
LC Doctor/Hot Rodder
Postby Bunsen » 14 Nov 2007, 16:25
I'm actually hoping I can pick up a USB-ADB adapter at a non-ridiculous price. I want to keep using my Extended KBII, Logitech trackball and Wacom graphics tablet. For now, I'm borrowing my housemate's iMac keyboard till I find either a USB set or the USB-PS/2 converters I know I have .... somewhere.
Believe it or not, I don't seem to have any PS/2 keyboards about the place. I know there's a box of mice ... somewhere.
Tonight it's up and running with the dual 533 G4s. I had to cut the connector off the CPU shroud fan, solder the leads to a couple of pins (made, literally, from pins) heatshrink them into a neat little bundle and shove them into yet another unused floppy connector. And the case fan has quietened down a lot - must have been cranky from lack of use.
That was after the hour I spent making up a disk power double adapter from a dead PS - then realising it didn't have a female connector. :?:
My *ahem* backup 10.3 CDs aren't booting; 10.2 is but there are "problems installing the software; please try again". I suspect a flaky CD drive. I tried my hard-rubbish-day Pioneer DVDR, but that doesn't appear to be bootable. Next attempt will be a slower CD drive, because that seemed to help last time on the beige.
Dunno if it's relevant or not but the drive I'm installing to is 160GB. I've formatted the space that can be seen (132GB) into four partitions.
I do have a PCI ATA controller and a SCSI card, but I don't know if they are supported under OS X or not, so I haven't tried to install them yet.
Right now DiskWarrior is having a go at repairing the 10.2 HD out of my beige.
have you searched? Seeks: Nubus PDS DSP PB170 Newton; TRS-80 III/4; CBM BBC SX-64 CX5M Likes: 8bit luggable palmtop terminal NC tablet audio MIDI analog FM drum synth steam&dieselpunk; 1930-1980 lab/comm/mil Score! NC100 PB190 Q950 IIe-PDS
User avatar
Bunsen
Witchfinder-General
Postby madmax_2069 » 18 Nov 2007, 23:39
yea it sounds like the optical drive is having issues with the install CD/DVD.
replace it and hope for the best. i have a Pioneer DVR-110D in my DA and so far so good it works 100%
Digital Audio, Yikes, Beige G3 AIO, P 475, Newton MP 2100, Apple IIgs, HP D530 SFF, wyse winterm 3360SE
http://www.Apple2online.com
User avatar
madmax_2069
Postby LSD » 19 Nov 2007, 00:24
I put a DVR-112 in mine. Took a bit of doing to get it in there (drive is shorter than normal and the shield cage wouldn't go in far enough so I had to reverse the power cables to make it all fit right) but it works great. It even boots off it.
User avatar
LSD
Postby Bunsen » 19 Nov 2007, 19:55
Optical drive, machine, and install disc seems to be one of those unsolvable three-body problems they told me about in math class. The drive in the DA boots other CDs, the 10.3 CDs boot in other machines (enough to tell me it won't install on a Beige for example)
Hmm, maybe I'll try the drive from the Beige
User avatar
Bunsen
Witchfinder-General
Postby dbraverman88 » 20 Nov 2007, 03:01
Bunsen wrote:AGP video is working
Bunsen,
Which card did you decide to use. BTW: I am using a 32MB AGP GeForce2 MX in my DA without any problems. Though there are games that don't like it and want more power.
--David
dbraverman88
Postby Bunsen » 21 Nov 2007, 20:19
Just an old Radeon 128 I had lying around for the moment.
On the OS front, I think I found the problem :-/ Ruddy great scratch right through the dye layer over the very innermost tracks on the first CD. I've ordered a legit DVD of 10.4 from the US. Should be here any day.
The 10.3's I have are burnt wrong. The contents that should be on the top layer of the heirarchy are inside a folder and not bootable (strange that they seemed to on the Beige, but perhaps my memory is fuzzy).
I rang a local Mac help shop and asked if they had any CDs of 10.3 (for two 'books I'm also working on), expecting legit old stock. Turned up and was handed burns. They don't work either :-/ So I'm also buying some legit 10.3s on ebay (local)
Bah. Crime doesn't pay.
User avatar
Bunsen
Witchfinder-General
Postby LSD » 22 Nov 2007, 17:44
You don't want to go overboard on the video front, not without considering the CPU. I have a flashed 9800 Pro in my DA and performance in even the most basic tests is pretty embarassing (In the OpenGL test in Xbench, for example. my GMA950 MacBook scores 8 times higher and my B&W G3 with its PCI Rage 128 only scres 18fps less) because the 733Mhz Quicksilver CPU I have in it simply can't feed the card fast enough. The card achieves what I bought it for (decent Core Image/Quartz Extreme support) but it's a bit disappointing that I can't get some gaming done on the side with it. I'm thinking awful serious about getting one of those aftermarket G4 upgrade CPUs, something in the order of 1.4-1.6GHz, but that won't happen until after I've maxed out the RAM.
User avatar
LSD
Postby Bunsen » 24 Nov 2007, 05:11
My main ambition with improved video is to free up CPU time for audio processing. So it's a cost-benefit balance between the video card, the CPU and a dedicated audio DSP card. And I gather having a dual-processor will help.
As far as gaming goes, meh. Marathon runs fine on my 6100 :)
User avatar
Bunsen
Witchfinder-General
Postby MacJunky » 25 Nov 2007, 00:02
I would say a dual 7455 might be best on performance and budget personally. I don't know if you have access to any decently priced ones though.
LC 630, P580CD, LC 575, Mac Plus X2, PowerBook 160, PowerBook 150 X2, PowerBook 145
User avatar
MacJunky
Postby Bunsen » 25 Nov 2007, 14:05
I've already got a dual 533 in there. Sorry, thought I'd mentioned that above in the thread somewhere.
User avatar
Bunsen
Witchfinder-General
Postby Bunsen » 26 Nov 2007, 07:59
10.4 has arrived; iMate on the way thanks to Dr Webster at the 'fritter; USB kb and mouse lined up for setting up; ATA controller to be scavenged from my 9500: further updates soon
User avatar
Bunsen
Witchfinder-General
Postby Bunsen » 08 Feb 2008, 16:19
Immediate plans (ie running adequately soon):
    * triple boot OS 9, OS X and *nix (NetBSD, Ubuntu or Yellow Dog)
    * Windows via Virtual PC and/or PC Compatibility Card
    * 2 x 160GB Seagates on an ATA RAID card
    * 80GB boot Seagate
    * Matsushita, Phillips or Samsung DVD-R
    * USB floppy drive
    * Flash card reader
    * SCSI card
    * Rage 128 AGP + Rage 128 PCI running:
    * 2 x 21" Dell Trinitron CRTs
    * USB-ADB, Apple Extended KBII, Kensington Turbo Mouse (huge trackball with multiple buttons)
    * Tascam US-428 audio/MIDI interface and control surface
    * MIDI keyboard and knob box
    * 600W per side pro power amp running a pair of semi pro monitoring speakers.
    * Apple Laser Printer and Stylewriter 2500
    * Scanner
Everything above I have on hand bar one more 160GB Seagate. One of the Dells may have issues, in which case I'll whack me old faithful Apple 16" on it for now.
Further plans (ie as time, need and budget allow):
    * Lots of sound dampening and silent-PC-ification
    * Windows via MiniITX motherboard and VNC
    * Dual head AGP Radeon
    * Third monitor
    * Overclocking
    * Max out the RAM
    * SATA or Firewire RAID
    * Beefier CPU and/or dedicated audio DSP card
    * Case mods (such as front mounting mutiple drives)
    * Enormous concrete subwoofer of doooooooom }:)
User avatar
Bunsen
Witchfinder-General
Postby Quadraman » 09 Feb 2008, 06:13
Thread necromancer. :P
Apple IIe IIc IIGS. Mac 128/512k->Plus 2xPlus SE. Dismantled IIci LC580 6320. Frankenmac Q700/IIvx, 631CD+040, 7500. 6100/60AV /66DOS 6116CD. 6500 7600 9500 G4DA533 G3iMac700 PB150x2 1400
User avatar
Quadraman
Postby Bunsen » 09 Feb 2008, 12:30
<- eternal project procrastinator. Besides, I was overseas for a while
User avatar
Bunsen
Witchfinder-General
Previous
Return to Conquests
Who is online
Users browsing this forum: No registered users and 2 guests
