Another IIci ROM hack
Re: Another IIci ROM hack
Postby dougg3 » 27 Oct 2011, 01:56
Update time! I just received my tracking number for the PCBs today from Seeed Studio, and lo and behold, they were out for delivery. So with an order placed on Monday, Oct. 17, that was a 9-day turnaround with the UPS shipping. UPS claims it was shipped on October 24th, so it only took 2 days to arrive here (well, except for time zone differences, so I don't know for sure). Anyway, very nice! Seeed must not have been feeling quite as generous, since I only received 10 this time instead of 12, but since I only paid for 10, you won't hear any complaining from me!
They arrived on the same day as my hardcopy of the Steve Jobs biography from Amazon. Coincidence, or is it a sign from above??? ;-)
Here are the revision 2 PCBs:
Looks like they turned out nice! I love olePigeon's jolly roger graphic -- with the LEDs it's going to look AWESOME. I wonder what the PCB manufacturers thought when they saw that? ;-) The vias are, in fact, big enough for the header now:
You'll notice the second pin from the left is shorter -- I believe this is from me pulling it in and out several times to test stuff out. The header has to go out from the back side with the graphic and capacitors, because if it goes out the front, the IIci's cache slot is in the way when you try to insert it. If other motherboards have similar clearance issues on the back side, I may have to abandon the programming header idea. But I'm hoping to make it work with 64-pin SIMM sockets anyway. :-)
I haven't done any electrical testing, so I may do that just to confirm Seeed Studio's testing, and build one soon! Unfortunately I didn't expect the PCBs to arrive so quickly, so the resistors and LEDs are still en route. Still, I should be able to build one and leave the LED circuit out just to test the functionality. And who knows, maybe the extra parts will arrive soon anyway? We'll see when I get around to building one!
dougg3
Postby Trash80toHP_Mini » 27 Oct 2011, 02:35
VERY, VERY 8-) !!!!!!!!!!!!!!!!!!!!!
I can't wait to test one with just about every 68030 ROM image under the sun!
My IIfx ROM SIMM in IIsi saga continues . . . ::)
jt [8]
Trash Hauler: call sign: eight-ball
C.O. AC130H SpecOps 68kMLAAF
User avatar
Trash80toHP_Mini
NIGHT STALKER
Postby dougg3 » 27 Oct 2011, 04:48
Unfortunately, at least one of the SIMM PCBs is not testing OK -- I'm finding several instances of adjacent pins being electrically connected together. It may have happened after I increased the size of the vias above the SIMM contacts to make room for headers to fit. (This was one of the untested boards--one of the tested boards I also looked at does not have this problem). I'll have to try to physically find the problem, and hopefully it's fixable with an X-acto knife! I couldn't find anything after a quick inspection but I'll look at it more thoroughly tomorrow. This means I'm going to have to test every (un-marked) board before I assemble it.
dougg3
Postby olePigeon » 27 Oct 2011, 16:59
[Butthead]This is the coolest thing I have ever seen.[/Butthead]
Oh man, I can't wait. :)
So the holes are there for possible future programming via a USB board? [Edit: Nevermind, just read it]
User avatar
olePigeon
Postby olePigeon » 27 Oct 2011, 17:16
dougg3 wrote:But I'm hoping to make it work with 64-pin SIMM sockets anyway. :-)
White with metal clips?
Or black with single tension clip?
And how many? :D
User avatar
olePigeon
Postby tt » 27 Oct 2011, 19:12
olePigeon wrote:And how many?
Cool, I found there's a local shop that also has these, so it looks like there are plenty to go around.
Metal clips are probably better.
User avatar
tt
Postby olePigeon » 27 Oct 2011, 19:25
Certainly less stress on the board to do the 45° and snap in place than to push down until the white clip locks.
User avatar
olePigeon
Postby dougg3 » 28 Oct 2011, 01:16
I like the metal clip idea too. So now we have both tt and olePigeon with sources for the 64-pin sockets. Hopefully the ones you both have access to are compatible with each other!!! This is excellent news! I'm excited to make a USB programmer board now.
Now, I will get to figuring out why some of the nets on the untested SIMM are shorted together!
Edit: Upon further inspection, here's what's going on with the shorted stuff:
Definitely fixable with the X-acto knife, but annoying. So it's NOT my vias being bigger causing problems after all. Disappointing especially after my first flawless experience with Seeed Studio, but I can deal with it (especially for the price). The traces look fine, and this only appears to be a problem with the contacts on the bottom of the board; the contacts on the top are fine.
dougg3
Postby bigmessowires » 28 Oct 2011, 03:10
Hmm, why is the section of the board under the edge connector pads a darker shade of red than the rest? Does it not have soldermask on it or something?
User avatar
bigmessowires
Postby Trash80toHP_Mini » 28 Oct 2011, 04:05
dougg3 wrote:Definitely fixable with the X-acto knife, but annoying.
CrapShack has a MUCH better tool for that purpose, mine's an angled wedge blade and a bent point probe "connected" by an octagonal yellow plastic handle.
So it's NOT my vias being bigger causing problems after all. Disappointing especially after my first flawless experience with Seed Studio, but I can deal with it (especially for the price)
If you got the board yield you requested along with the "untested overrun," and they're fixable, I'd say your experience has remained flawless! :approve:
jt [8]
User avatar
Trash80toHP_Mini
NIGHT STALKER
Postby dougg3 » 28 Oct 2011, 04:25
bigmessowires wrote:Hmm, why is the section of the board under the edge connector pads a darker shade of red than the rest? Does it not have soldermask on it or something?
Yeah, there's no soldermask there. The connectors are so close together that my PCB software leaves it out of the entire area. It looks like I'm leaving 8 mils of clearance around pads and Seeed will let me go down to 0.1 mm (about 4 mils), so I might try 4 mils on the next batch.
Is it solder that is bridging between the pads in that picture? I guess I didn't pay attention...so in that case, the mask would have helped against the problem I'm seeing, right? I would assume they add the solder coating to the pads after everything else is finished with the boards?
I live in the middle of nowhere where we don't have Radio Shack anymore :( Interesting, what is the tool designed for originally?
Trash80toHP_Mini wrote:If you got the board yield you requested along with the "untested overrun," and they're fixable, I'd say your experience has remained flawless! :approve:
Well, I ordered 10 boards and 50% electrical testing. I received 10 boards, with 5 of them marked as tested. One of the un-tested boards has that fixable problem and I haven't checked the others yet. I guess this would be a good reason to pay $10 for the 100% testing service. Anyway, not really a complaint on my part, it's not a huge deal. But I'm glad I checked the board *before* assembling it because otherwise I would have been freaking out trying to find shorts in my own soldering, which would be hard to see underneath the sockets :)
Can't wait to get the programmer board working, because then the chips can be soldered directly onto the SIMM! (Or I can put sockets on anyway if requested by the super hackers)
dougg3
Postby olePigeon » 28 Oct 2011, 17:15
I vote keeping the sockets if it's not much more difficult. If you do the unimaginable and mess up one of the ROMs, it's much easier to replace. :)
User avatar
olePigeon
Postby Arbee » 28 Oct 2011, 17:41
Hey dougg3,
Nice work :) I'm glad the MESS ASC code was able to help. Our IIci emulation plays music and game sounds great in both games and things like PlayerPRO so I'm pretty confident in both the wavetable and FIFO mode emulation for the original ASC. The stripped-down ASC inside the V8 ASIC (LC/LC II) has not-quite-compatible registers, and LC III's Sonora is different yet again. The Enhanced ASC (which Apple calls "Batman") removes the wavetable mode entirely and has real variable sample rate and volume control on the FIFOs.
Arbee
Postby dougg3 » 29 Oct 2011, 00:51
On second thought, there's only about 10 mils between the pads, so I don't think Seeed will be able to fit much solder mask in there anyway (only 2 mils). Probably not worth changing...
olePigeon wrote:I vote keeping the sockets if it's not much more difficult. If you do the unimaginable and mess up one of the ROMs, it's much easier to replace. :)
Since I'm not a high-volume operation, I'll ask each person what they want :) The sockets add some cost to the board, but I see what you mean. For now I have to use sockets anyway, since I don't have the programmer board ready.
Arbee wrote:Hey dougg3,
Thanks Arbee! The ASC emulation in MESS is fantastic! Awesome work! Without MESS there's no way I would have figured it all out. How did you figure out what all the bits do? Was it basically a matter of disassembling the OS/ROM and looking at how the registers are accessed?
SIMM update: The resistors and LEDs have arrived. So I have all the parts needed to build some rev. 2 SIMMs. I may just have to put some resistors and LEDs on an otherwise unpopulated board to test out the glowing eyes circuit with a bench power supply :-)
dougg3
Postby dougg3 » 29 Oct 2011, 19:40
Just in time for Halloween.
It's aliiiiive....it's aliiiiiiiiive...
The LED circuit definitely works. My camera doesn't do well with the huge difference in brightness between the rest of the board and the LEDs, but it DEFINITELY works! Now to assemble the rest of the board. More soon...
dougg3
Postby dougg3 » 30 Oct 2011, 00:10
Well, I'm fighting one hell of a battle assembling this SIMM. I *really* can't wait to ditch the sockets.
I'm finding annoying shorts between pins. It looks like all the solder paste isn't necessarily flowing nicely where it's supposed to go, or something. Every time I fix a short, I check for other shorts and don't find any, so I wash the board. Then, I come back after it's dry, and there's ANOTHER short! The worst part is that there are 4 possible sockets the short can be on and I can't see any of them, so it's basically "try to get some flux in that location on each socket, heat up the pins, and cross your fingers". Repeat, until the short goes away.
The shorts are gone according to my multimeter -- except for one I CANNOT for the life of me fix between VCC and write enable, but it doesn't matter right now because that would only prevent programming it from the external board -- when I put it in the IIci those pins are connected together anyway.
But it just won't boot. I got it to boot once with a set of smaller EEPROMs inside, but now it won't work at all. I'm thinking there may be a loose pin somewhere, but I'm too frustrated to keep working on it today.
On the bright side (no pun intended), the LEDs work great! They are looking good and they are extremely bright. Maybe too bright!
dougg3
Postby Trash80toHP_Mini » 30 Oct 2011, 04:06
Fabulous progress, doug, it's Miller time! [:D]
jt [8]
User avatar
Trash80toHP_Mini
NIGHT STALKER
Postby dougg3 » 30 Oct 2011, 04:38
Thanks :) for sure!
I actually went back to it tonight and fixed that last short by adding more solder, which seemed to get the existing solder flowing. I also fixed a loose pin. At this point the SIMM tests perfect electrically but still won't boot.
I think I will start fresh with another PCB, and go back to cutting out the bottom plate for simpler soldering. I'll also leave out the LED parts until I know the SIMM can boot my IIci.
dougg3
Postby bigmessowires » 30 Oct 2011, 16:59
dougg3 wrote:At this point the SIMM tests perfect electrically but still won't boot.
Rats. How are you doing the electronic testing-- with a multimeter, checking for shorts or opens everywhere? It sounds like you already tested pretty thoroughly for short circuits everywhere, but maybe there's an open (broken connection) that you missed? Or maybe one of the chips isn't socketed firmly, or there's some corrosion on a pin preventing it from making good contact with the socket?
I've forgotten now why you used SMD sockets instead of through hole ones. It sounds like the SMD ones are a pain in the butt! :-)
It would be tedious, but you might try manually reading out some EPROM values by connecting appropriate high and low voltages to your SIMM connector pads with alligator clips or something. That way you'd be reading it the same way the Mac does, from the same contacts.
User avatar
bigmessowires
Postby Trash80toHP_Mini » 30 Oct 2011, 17:46
Addendum to BMOW's suggestion:
If you've got a ROM SIMM Socket, one of the larger ones would actually be better, build yourself a testing setup/prototype of the read portion of the programmer circuit in the same step. Wire wrap on a stock project/prototyping PCB would be my medium of choice for such a rig.
BTW: 15 pages & counting! Nice initial post Mr. very much EX-noob around this nook-o-da-web! :approve:
jt [8]
User avatar
Trash80toHP_Mini
NIGHT STALKER
Postby dougg3 » 30 Oct 2011, 18:09
I'm testing using a multimeter to be sure that every connection that is supposed to be connected is connected -- so that except for the data lines, the corresponding pins on each socket are connected together, and that there are no shorts between nearby socket pins. I also have checked that each SIMM contact is connected to the correct socket pins. So yeah, I'm looking for both opens and shorts.
It could definitely be a loose socket connection, PLCC sockets are pretty flimsy.
I used SMD sockets because they are physically smaller and because the through holes eat up a bunch of routing space on the bottom of the board. The SMD sockets aren't terrible to work with if I cut out the bottom plastic plate, so I'm going to try that.
I'm just not equipped to read values from the board yet, but I really like the idea! I don't have enough alligator clips and stuff to put a 0 for example on every address line and CS and OE. Likewise I don't have any SIMM sockets yet either :)
Thanks for the ideas guys! Today is a fresh new day so hopefully I can get to the bottom of it.
Edit: I just found another weird short that I hadn't found yesterday. It's not between nearby pins, but that's clearly because it's between a pin and a nearby via. I can't see it, but that HAS to be where it is. This board may be fixable after all!
dougg3
Postby dougg3 » 30 Oct 2011, 21:18
Success! It was that last short I just found, and the SIMM works now. That makes me happy because I know that the rev 2 board works now.
I just made another SIMM which I did more carefully, and it had one short. I fixed that and it began to work, but halfway through the crazy long startup chime, it went all nuts. It didn't work after that. I then found ANOTHER short which was NOT there before, so I'm 99% sure that the solder paste is to blame. I took the board and very thoroughly washed it with cold water, and then the short disappeared. I'm still letting it dry now so I don't know if it will work after that, but weird, huh?
I used less paste this time which helped, but I think what's happening is some extra unheated paste is getting left behind and intermittently causing problems.
Until I have a reflow oven working that can heat up ALL the paste, I will probably return to cutting out the bottoms of the sockets and using regular solder. That combination has worked for all other boards I have made with no problems. Anyway, success!
dougg3
Postby dougg3 » 30 Oct 2011, 23:19
And now I've been hit with another unexpected curveball.
The IIci motherboard I've been using to test my SIMMs with is no longer functional. When I hit the power button on either the back or the keyboard, nothing happens, nada. It's not the power supply -- the power supply boots my hacked IIci motherboard fine, and it's definitely putting out the 5V trickle voltage.
This is a motherboard which I have not recapped or cleaned at all, so it's possible that's all it needs, but it's funny that it just started doing it now that I'm messing with the rev. 2 SIMM. I'm not even going to touch my hacked motherboard with these SIMMs until I figure out what's going on with my now non-functional motherboard.
*sigh*
P.S. I was thinking, my SIMM programmer board should be able to test for shorts...that will be very handy. It won't be able to tell me which chip/socket it's on (except for the data pins), but that will be very helpful for testing.
dougg3
Postby olePigeon » 30 Oct 2011, 23:52
Thanks for keeping us posted. I'm anxiously waiting.
Out of curiosity,did the LED eyes light up when the SIMM is inserted? Or are you testing it without the LEDs? I saw the picture you made and it looks awesome.
User avatar
olePigeon
Postby dougg3 » 31 Oct 2011, 00:23
Yep, the LEDs light up as soon as power is turned on (well, they did until my motherboard gave up the ghost). They look great!
dougg3
PreviousNext
Return to Hacks & Development
Who is online
Users browsing this forum: No registered users and 2 guests
