(The costs of 0.8mm, 1.0mm, 1.2mm, and 1.6mm are same)
dougg3 wrote:Are you talking like axial electrolytic capacitors, or something else? What kind of capacitor could I use? Either way, I like it! I didn't even consider just skipping surface mount capacitors. With the through hole sockets, it may be easier just to use through hole capacitors as well. Pretty coolI think this may work out OK actually.
Trash80toHP_Mini wrote:Keira Knightley?
Users browsing this forum: No registered users and 1 guest
