Cache issue, /w G3 Bronze kbd ebay find
Postby uniserver » 24 Apr 2012, 07:26
when i boot it up it says the built-in memory test has detected a problem with chache memory, please contact a service tech for assisance
in system profiler it says i have zero L2 cache,
also somtimes it doesent boot unless i hold the reset button down for 5 seconds to reset the pram, but its booted now, into os 8.6
i am posting this with it.
i would assume i would need a new processor card for this bad boy huh?
User avatar
uniserver
Re: Cache issue, /w G3 Bronze kbd ebay find
Postby CC_333 » 25 Apr 2012, 18:00
Hi,
uniserver wrote:also somtimes it doesent boot unless i hold the reset button down for 5 seconds to reset the pram, but its booted now, into os 8.6
I don't know what that's about. Maybe the bad cache is corrupting something in PRAM?
uniserver wrote:i would assume i would need a new processor card for this bad boy huh?
Yeah, I'd say you do.
I had this happen to a Pismo (except I couldn't get it to run without hard freezing. It was running OS 9.x.x). I replaced the CPU card and it was as good as new.
You could try unplugging it and putting it back to clear any corrosion on the connectors, although I doubt that would work if your L2 cache is out.
I hope you get it fixed!
c
User avatar
CC_333
Postby BGoins12 » 25 Apr 2012, 19:07
Cache failures are common on the Lombard and Pismo. I think the only way to solve it is to replace the CPU card.
2.5 i5 Mac Mini (Late '12), Dual 1.25 MDD, 1.42 eMac, 5500/275, 7600/120, 8500/120, 7100/80AV, 6100/66, LCII (w/LCIII Board), PB 520, a few PCs, and a 8GB Nook Tablet. More in my link --------->
User avatar
BGoins12
Postby Blessed Cheesemaker » 30 Jun 2012, 17:35
Sorry to resurrect a dead topic, but I have some experience with Lombards and dead caches...
Basically, the only real effect of the dead cache will be that message upon startup. Once you hit the "OK", it will boot up normally. You won't have any Level 2 cache then, so some programs will see a slight decrease in performance (roughly 20% max, if I remember the old MacBench benchmarks). In reality, you likely won't notice much of a difference, if at all, in your user experience.
The good news is, it should run slightly cooler without the cache. This will also mean that you should get slightly longer battery life, but I'm guessing your battery is already likely dead, and spending $80-$100 for a replacement at OWC is too cost prohibitive.
The other negative you should be aware of (I found this out the hard way)-->OS X will *not* install on a Lombard with dead cache (the Classic OS's will still install, however). The weird thing is, if you already have OS X installed on the Lombard, and reboot, it doesn't run the memory check like OS 8.6 and OS 9 did (well, it may run it, but it doesn't interrupt the booting process to say anything to you). In that case, if you want to install OS X, you will either have to get a different processor, or have another computer install it to an external 2.5 inch drive, and then place it internally. (How did I find this out? I bought a Lombard on ebay with 10.3 installed, made sure it ran ok, then decided to do a fresh install of Panther...after wiping the drive, and starting the install, I found out that I was screwed...installing Classic then told me that the cache was dead...).
Be excellent to each other!
User avatar
Blessed Cheesemaker
Return to PPC PowerBook & iBook
Who is online
Users browsing this forum: Google [Bot] and 1 guest
