iBook Battery Info?
iBook Battery Info?
Postby CelGen » 01 Apr 2012, 17:05
I want to go through a stack of batteries I have that piled up for my Indigo clamshell iBook but unlike later on in 10.6 and a white Macbook where I can just plug batteries in and get the Battery Info right then and there, I'm finding no such information tab under 10.3.9 All I get is the battery bar and "CALCULATING..." which isn't really of any use. I was told somewhere (it might of been here) that the best chance to revive iBook batteries is to charge them while running OS X (which sounds a tad weird) but I'm not sure if this is what they ment, or if I'm missing an additional step.
User avatar
CelGen
Re: iBook Battery Info?
Postby Mk.558 » 01 Apr 2012, 19:46
If you have the Clamshell with FireWire, then you can use this with 10.4.11 to let you know what is going on.
SE/30 Cap Replacement http://tinyurl.com/7r7jjor
Classic Mac Networking http://applefool.com/se30/
"Linux assumes you know exactly what you are doing." -oboedad55, ubuntuforums.org
User avatar
Mk.558
Postby CelGen » 02 Apr 2012, 00:25
...right. I just spent last night installing and updating 10.3 too.... :-/
User avatar
CelGen
Return to PPC PowerBook & iBook
Who is online
Users browsing this forum: No registered users and 2 guests
