Just resurrected a dead 5300CS!
Postby switch998 » 25 Feb 2012, 05:36
Last week, I bought a powerbook 5300cs that wouldn't power up, according to the owner, for $5 locally. Figured it just needed a new power jack. Turns out pressing the reset button would sometimes yield a green light only, a chime and then freezing, or just some noise from the speakers. I took the laptop apart and found no obvious signs of any damage, but when I looked closely at the processor, I noticed that one side of the processor's pins broke free from the logic board!
Anyway, I resoldered (by hand ;) ) all of the 603e's pins, and got the machine up and running again. Since I figure the heat from the processor caused the solder to crack in the first place, I applied a little bit of thermal paste to the chip.
Hopefully this helps anyone that has a powerbook with similar issues ;)
switch998
Re: Just resurrected a dead 5300CS!
Postby Bunsen » 29 Feb 2012, 14:43
Hahaha I just reached for the "Like" button. Gotta spend less time on Faceborg.
Well done :) Have you ever done any soldering at that pitch before?
have you searched? Seeks: Nubus PDS DSP PB170 Newton; TRS-80 III/4; CBM BBC SX-64 CX5M Likes: 8bit luggable palmtop terminal NC tablet audio MIDI analog FM drum synth steam&dieselpunk; 1930-1980 lab/comm/mil Score! NC100 PB190 Q950 IIe-PDS
User avatar
Bunsen
Witchfinder-General
Postby J English Smith » 29 Feb 2012, 15:52
Baby that hard drive...one of mine just gave up the ghost, and it was quite a chore refitting the drive sled to take a 12.5" factor drive from a 1400. The originals for the 5300 were these weird 17mm drives with holes in different places.
Congrats on the successful resoldering!
Macs: Classic II (7.1), Centris 610 (7.5.3), PB 150 (7.6), PB 5300cs (7.6 and 8.0), PB 1400c/cs (8.0 and 8.6), PB G3 Lombards (10.4.11), several Pismos (10.4.11)
PCs: Dell Dimension (Win 98se), IBM ThinkTower (Win XP sp3), Toshiba Satellite (Win 7)
J English Smith
Postby switch998 » 01 Mar 2012, 03:36
Bunsen wrote:Hahaha I just reached for the "Like" button. Gotta spend less time on Faceborg.
As a matter of fact, yes :D I've done micro-BGA stuff by hand (Well, the stencil part) in the past too. Just an FYI, you can make a decent buck on eBay through repairing macs.
Either way it was pretty damn frustrating, and it was a decent amount of work, but I would have hated tossing the powerbook.
switch998
Postby techknight » 02 Mar 2012, 05:08
Should have just gotten the reflow nozzle on your BGA station and did it that way. Thats what I do.
Main PC: Intel core I7 920, MSI x58 platinum, Radeon4850
PB: tibook G4, ibook G4, Lombard, 160, 165, 180, Duo 2300x2, Duo 270c x2, 520cPPC, 3400c, 1400c
Desktop: G3AIO, 5260/100 x2, SE, SE/30, 512k, plus, LCIII, 7100, iMac G5 iSight, 6400/225
techknight
Postby switch998 » 07 Apr 2012, 04:26
I was too afraid to burn the chip, and I wanted to put new solder on the pins, so the reflow station I have was not going to work (theres on way in hell I'll ever lay solder paste correctly).
switch998
Return to PPC PowerBook & iBook
Who is online
Users browsing this forum: No registered users and 1 guest
cron
