Powerbook G3 Lombard
Postby Strimkind » 04 Feb 2012, 08:16
I was attempting to sell this PB Lombard, but have had no takers. So I decided to swap the logic boards myself.
The original board would chime very static like and you could hear the HD power up, but the green light would not come on and it wouldn't do anything.
So I figured something was up with the video on the board so I decided to swap it with a spare board I have.
Not 5 minutes in I see why nothing was coming up on the LCD. The green cable from the LCD was broken right near the connector to the inverter board. One issue solved.
Decided to keep going and completed the install. Found a 2nd sound board, installed that too. Booted it up and still chiming static like and no change from before. Removed PRAM before doing this and reset the PMU. Nothing changed.
Now the unit is currently headless as I do not have a spare LCD. Is there any way to tell it to switch to external video or video mirroring? Anyone have any ideas if this issue may be caused by bad RAM or bad CPU?
Thanks!
Laptop: Late 2006 2ghz Black, Pismo 400, 1400c x 3
Duo: 230, 280c, 2300c x 3, mini dock x 2, Duo Dock II
Desktop: LC, LC 475, G4 Cube, IIfx, Umax C600, PM 8600, G4 1.4ghz DA, Mac Mini 2011 i7 2.5ghz
User avatar
Strimkind
Re: Powerbook G3 Lombard
Postby jruschme » 04 Feb 2012, 14:02
I seem to recall briefly running a headless Lombard and not having to do anything special other than not have the LCD hooked up and plugging in an SVGA monitor.
JR
13" MBP (late 2010), MDD G4/1000x2, Sawtooth G4/800, Pismo G3/500, Lombard G3/333, B&W G4/400
jruschme
Postby Strimkind » 06 Feb 2012, 04:59
Good to know. I'm starting to think that either the RAM or CPU is kaput here. As both logic boards produced the same results. The good thing of that is that I have two 'theoretically' working Lombard Logicboards.
User avatar
Strimkind
Return to PPC PowerBook & iBook
Who is online
Users browsing this forum: No registered users and 1 guest
