wgoodf wrote:cant say for 68k but would doubt it - the version being used for the WWU is a universal binary so you are in if you have a PPC Mac thats good enough.
check out the doom-retrochallenge site and take it from there/
wgoodf wrote:chesty i will miss you so!
conceitedjerk wrote:wgoodf wrote:chesty i will miss you so!
Awww, sorry mate. I can't bear to see you like this.
Just sent in my entry. I'll be resurrecting a few Amigas that have been comatose in the lab, namely my A4000D and both my A1200s, will probably do something with my A2000 and CDTV as well, with a dose of TRS-80 Model 100 for good measure.
Couldn't resist the pull after all... Everytime I think I'm out, they keep dragging me back in!
(I can't remember if my PCMCIA cage is the one-and-only model that works with the PPC upgrade. If it is, I'll use my 520c with PPC upgrade instead of the 540c.) I was going to have the cutoff be my step-son's fifth birthday (9/25/1999,) but that would exclude Mac OS 9; and I feel like using OS 9.
)2. In order to qualify, computer systems must use a pre-pentium processor... in general, this means 486 or below, 680x0 and pretty much everything with an 8-bit processor, but we'll also let you in if you have an old Cray kicking about.
conceitedjerk wrote:PPC ist verboten.
most 10 year old game systems are 2 generations old, leaving them with (at best) small meg's of memory, and 10's of megahertz
Users browsing this forum: No registered users and 1 guest
