Magento-optical disks/drives
Re: Magento-optical disks/drives
Postby Mk.558 » 28 Mar 2012, 03:53
Well, what I am thinking at the moment is that the best backup is a file that doesn't exist.
I don't do computer boot images, if I need a emergency boot disk set aside then a separate external HDD would be just fine.
Let's see here:
  • Archives (usually OS 9+, like 10.5.8 Combo, 10.2.8 Combo, older iTunes downloads, old Handbrake versions, the lot) ~14GB
  • Book library (mostly PDFs, and kludgy image dumps rather than OCRd stuff) ~11GB
  • Documents ~2.5GB
  • Games.dmg (mostly older stuff my 'mini won't even run) ~1.3GB
  • iTunes backup (Music+audio book=~1.7GB, rest is iOS backups, as I backup old versions of .ipas, it has been useful a couple of times) ~21GB
  • Movies (various) ~91GB
  • Classic Mac archives (system folder images, this and that) ~4GB
  • Pictures ~2GB
  • Slipstreamed XPSP2 .iso backups* and Windows archives of everything useful I find for Windows** 4GB
Free space on 250GB FAT32 volume: 77.53GB. If I put copies of OS X install DVDs, which would be nice since I have no confidence in Apple's future plans to maintain machine-specific 10.4.6 install disks for this machine, I'd best do it myself. Or 10.5 disks, but those should be around for awhile.
I'm thinking a stack of 15 MO disks should cover me just fine. Some of that stuff should ~really~ be backed up solid, that's what I figure the MO discs would be used for: the classic Mac stuff, archives, images, documents, et cetera.
*: This was before I learned that SP1 will not work properly in a 'mini
**: Everything I find useful for Windows gets backed up. Fortunately that isn't much, but as I have to spend lots of time finding stuff for Windows that works, I find it best to backup that which I find works so I don't have to hunt all over again for it.
SE/30 Cap Replacement http://tinyurl.com/7r7jjor
Classic Mac Networking http://applefool.com/se30/ < Working on version 3.0!
"Linux assumes you know exactly what you are doing." -oboedad55, ubuntuforums.org
User avatar
Mk.558
Postby techknight » 29 Mar 2012, 02:44
speaking of slipstreaming, i love that software that lets you customize windows installation CDs. I slipstream SATA drivers and slipstreamed SP3 this way.
n-Lite. even microsoft recommends it so ive heard.
Main PC: Intel core I7 920, MSI x58 platinum, Radeon4850
PB: tibook G4, ibook G4, Lombard, 160, 165, 180, Duo 2300x2, Duo 270c x2, 520cPPC, 3400c, 1400c
Desktop: G3AIO, 5260/100 x2, SE, SE/30, 512k, plus, LCIII, 7100, iMac G5 iSight, 6400/225
techknight
Previous
Return to Peripherals
Who is online
Users browsing this forum: No registered users and 2 guests
