SCSI to PCMCIA
SCSI to PCMCIA
Postby theos911 » 04 Aug 2011, 17:54
I'm working on a project as detailed in the Room of Duo to get a PCMCIA card slot into my Newertech UltraDock.(Should be arriving in a few days) However, the card cage they specified is nowhere to be found on the internet(PCD-500). So, I'm looking for something that would serve a similar purpose with a similar form-factor and is available to buy somewhere.
The main idea is that it connects to an SCSI plug and then converts that into PCMCIA slots. I've seen Micha's, but it is too large for this purpose. Does anyone have one of these, or know anywhere where I might be able to get one.
Thanks for any input, as I've hit several dead-ends only a few hours into this project :o)
68k: Duo 230, 270c, 280c, DuoDock II, DuoDock Plus, Apple Minidock, Newertech Netdock & Ultradock 16sce, 540c, 190
PPC: 2300c, 5300ce, Performa 6500, Wallstreet II 300, B&W Powermac G3 500, iMac G3 700
PRAM? When in doubt, Pull it out!
theos911
Re: SCSI to PCMCIA
Postby johnklos » 05 Sep 2011, 16:44
johnklos
Re: SCSI to PCMCIA
Postby theos911 » 05 Sep 2011, 18:13
Thank You!
Yes, something like that, though that one specifically might be too big for my intended application. I opened up the dock and it doesn't seem like there would be room for a 3.5" HDD. However, there isn't any way to know how much room can be saved by removing the case }:) . Length wise it would work. It is the width that troubles me. :-/
Also, just wondering, would something like this connected to an SCSI bus be able to act as anything other than storage? I know there were SCSI -> Ethernet adapters, but would that(or USB) be possible with this setup?
theos911
Re: SCSI to PCMCIA
Postby techknight » 06 Sep 2011, 02:46
my SCSI SSD project was based off of Micha's code. and i hit brick walls with it too. been too busy to get back to it.
at least the AHA card, it would do a full inquiry without crashing anything.
The mac just rejects it completely. Micha's code probably isnt fully compatible with SCSI-1 signaling. (only SCSI-3 compliant code).
Main PC: Intel core I7 920, MSI x58 platinum, Radeon4850
PB: tibook G4, ibook G4, Lombard, 160, 165, 180, Duo 2300x2, Duo 270c x2, 520cPPC, 3400c, 1400c
Desktop: G3AIO, 5260/100 x2, SE, SE/30, 512k, plus, LCIII, 7100, iMac G5 iSight, 6400/225
techknight
Return to Peripherals
Who is online
Users browsing this forum: No registered users and 1 guest
