Monopoly money for 1991 Nubus cards, and a v. peculiar card
Postby beachycove » 08 Mar 2010, 04:18
I have been doing bits and pieces of research on some recently acquired hardware. According to this snippet, the RasterOps 24XLI nubus card that I now have bouncing around in a cardboard box once cost $3500. And that $3500 was back in 1991.
Now I know that large screens were cutting edge and the technologies involved were of commercial importance to the burgeoning desktop publishing/ printing industry of the time, but really — $3500? How did the manufacturer get away with it?
The RasterOps 24XLI was, having said that, a rather interesting and obviously high-end video card which supported 24 bit colour on a 20" monitor without further ado, which was quite something back in 1991. The odd thing is that the 24XLI also contained 4 perfectly ordinary 30-pin SIMM slots. So once I get around to firing it up, I'm going to go with 4x 4MB SIMMS for 16MB in a video card from 1991, just to say that I'd done it.
The RAM added can apparently be used either for "Gworlds" use, which nubus video card aficianados will know all about — or, much more eccentrically ... for a RAM disk!
Why the latter functionality on a video card, do you suppose?
User avatar
beachycove
Re: Monopoly money for 1991 Nubus cards, and a v. peculiar card
Postby Unknown_K » 08 Mar 2010, 11:06
A 16MB RAM disk (extremely expensive back then) would hold a decent amount of graphics data allowing you to make edits without using the slow hard drives of the day (scratch disk).
Those Nubus cards were not exactly super fast moving data over the Nubus BUS, so having it stored on the card would make working with big images a whole lot faster.
Favorites: big box Mac IIs, 950, 800's
Wanted: Anything Nubus, Video capture and editing hardware and software for 68k mac. Original software including A/UX.
Looking for 9150, Mac II, Color classic, 840av motherboard, and Nubus cards.
User avatar
Unknown_K
Postby beachycove » 08 Mar 2010, 16:20
This LEM article offers a rather unflattering view of the card, and of its RAM disk capability, but I wonder if this could perhaps be related to the System software (7.5) under which it was tested?
Among the distinctly odd things about these old pieces of hardware is the disconnect between price paid and longevity; a parallel to this would be a nubus card like the 8/24GC from Apple itself, which was supposedly designed specifically for the IIfx (and its little bother, the IIci), both of which machines were designed with a view for the impending release of System 7. Yet the RISC processor and (in effect) separate OS included on the 8/24GC only works properly under System 6.
So you invested heavily ("It costs the eyes out of your head," would be a suitable French idiom for it), only to have a failure of support just a year or two later.
User avatar
beachycove
Postby Unknown_K » 08 Mar 2010, 18:53
The system 7 rollout caused all kinds of hell with video card makers, most of them had to rush out new ROM chips to be compatible. And I think the newer ROM versions didn't play well with OS 6.
User avatar
Unknown_K
Postby Bunsen » 10 Mar 2010, 08:04
beachycove wrote:The RAM added can apparently be used either for "Gworlds" use, which nubus video card aficionados will know all about
I've heard of it, but so far, nope, no idea what it is. Anyone?
have you searched? Seeks: Nubus PDS DSP PB170 Newton; TRS-80 III/4; CBM BBC SX-64 CX5M Likes: 8bit luggable palmtop terminal NC tablet audio MIDI analog FM drum synth steam&dieselpunk; 1930-1980 lab/comm/mil Score! NC100 PB190 Q950 IIe-PDS
User avatar
Bunsen
Witchfinder-General
Postby Gorgonops » 10 Mar 2010, 16:58
What "Gworlds" is? Eh. Creative googling will sort of explain it:
http://www.mactech.com/articles/develop ... olumn.html
http://developer.apple.com/legacy/mac/l ... raw-2.html
... (Look at the chapter about "offscreen graphics worlds) and they're mentioned in passing in the Wikipedia article on Quickdraw. To oversimplify, it basically seems to boil down to being a form of "double-buffering" in which pointers are set so that Quickdraw, rather than drawing directly to video RAM, renders a complex image element to a RAM buffer which is copied to the display device when it's finished. Apparently it was possible with these Nubus cards with SIMM slots to set the render pointers to the RAM cache on the card so the CPU would render to the offscreen buffer there instead of system RAM, and when the image was ready to display it could be simply blitted by the video card's hardware into VRAM rather than transferred over Nubus. (Which would be comparatively slow compared to a memory-to-memory transfer on the card itself.)
An application had to specifically support doing this, so having that memory in most cases doesn't make anything faster. And apparently OS updates had a bad habit of breaking apps that did do it.
User avatar
Gorgonops
Postby beachycove » 13 Mar 2010, 02:02
And here 'tis.
User avatar
beachycove
Postby Unknown_K » 13 Mar 2010, 02:43
Nice card, is it raining Nubus up in Ontario?
User avatar
Unknown_K
Postby beachycove » 13 Mar 2010, 03:03
Sure seemed to rain them last weekend. I must have gotten 25, though many are just NICs.
User avatar
beachycove
Postby ClassicHasClass » 13 Mar 2010, 03:25
Actually, I get perfect performance with my 8*24*GC under 7.1 with acceleration. Naturally it isn't happy in A/UX or 7.5, but it's perfectly stable and very speedy in 7.1.
User avatar
ClassicHasClass
Postby mac2geezer » 13 Mar 2010, 03:56
What display resolution do you get with the 8.24GC? I can't seem to get better than 640x480 in 7.6.1 on the IIfx driving a 15 inch Apple monitor. The monitor is capable of better res on other cards, so it's not likely that's the problem.
IIfx 80MB 1.2GB HD, slot load G3 iMAC, 20 in C2D iMAC, 8600/300, 9600/300 w G4/800, 2.3GHz DC G5, Powerbook G4
mac2geezer
Postby ClassicHasClass » 13 Mar 2010, 16:09
I have it set to 640x480 because that's what I use on that screen, but I'll see how high I can get. Maybe it's something about 7.6.
User avatar
ClassicHasClass
Postby beachycove » 13 Mar 2010, 16:38
I was pleased to hear that the 8 24GC works under 7.1. I have been doing some further googling in response to this piece of information, and now see that there were ROM updates for a while.
As the article referenced shows, it was quite the nubus card.
As for resolution, I think it is meant to drive a large monitor quite happily at 1024x768 or better.
User avatar
beachycove
Postby ClassicHasClass » 14 Mar 2010, 20:09
I forgot that that monitor has a converter DIP box on it, so I'll have to try later (it's forcing a particular resolution) when I can find the DIP setting page again. In the meantime, though, I think it also depends greatly on how much RAM is installed. I was very fortunate to find a card with the full 8MB of option RAM installed (for a total of 10MB, including the built-in 2MB buffer). If yours is RAM impaired, maybe that explains the problem.
User avatar
ClassicHasClass
Postby Unknown_K » 15 Mar 2010, 00:37
That has 2 sockets for GWORLD RAM and not video RAM correct?
User avatar
Unknown_K
Postby beachycove » 15 Mar 2010, 00:47
As it has come up, could you tell us what RAM chips are in the 8 24CG that you have? There are conflicting reports concerning whether or not IIfx RAM works, and I am thinking of trying to find the chips if I can find out precisely what to look for. 8MB would be rather good in the card, I think.
User avatar
beachycove
Postby ClassicHasClass » 15 Mar 2010, 13:22
The RAM can be used for GWorlds, but I don't know if it has any other feature. Incidentally, found this rather nice article: http://www.mactech.com/articles/develop ... _V007.html That article simply calls it DRAM for the GC kernel, so I might be wrong about resolution depending on it. However, LEM says it can go up to 1152 x 870, though I have never tried that resolution: http://lowendmac.com/video/apple8-24gc.shtml
Anyway, they appear to be 64-pin sticks, and they do resemble the IIfx sticks I have seen. The chip code is (Samsung?) KM44C256AJ-8.
User avatar
ClassicHasClass
Postby Unknown_K » 15 Mar 2010, 18:53
The Gworld RAM for the Supermac cards are also 64pin, which is where the confusion comes in.
I don't have a 8.24GC to know what it takes, but I do have RAM in my Supermac Thunder/24 cards and it is not IIfx RAM.
User avatar
Unknown_K
Postby beachycove » 16 Mar 2010, 01:25
Well there are LOTS of hits from "KM44C256AJ-8" if you do a search, but I am wondering if this is the number of the chip used on the vram card or the number of the card part itself. I get mixed messages from a hit like this, which on the one hand makes the part look cheap and readily available, but which also suggests that the number refers to the SOJ used rather than to the part number of the actual vram needed.
Still, very helpful lead.
User avatar
beachycove
Postby Unknown_K » 16 Mar 2010, 03:29
The is a memory chip, not the complete SIMM you are searching for.
User avatar
Unknown_K
Postby ClassicHasClass » 16 Mar 2010, 03:34
Sorry, I misunderstood what ID you wanted. The P/N is 333-0167 (C)1989 APPLE.
User avatar
ClassicHasClass
Postby mac2geezer » 16 Mar 2010, 17:50
I can confirm from experience that IIfx Simms do not work in the 8-24GC slots. Physically they fit, but the IIfx will not boot with those Simms installed, it won't even chime.
To be clear, my IIfx wouldn't boot; YMMV.
mac2geezer
Postby Quadraman » 19 Mar 2010, 06:00
I'll say this. If I EVER pay $3500 for a video card, that company better damn well still be in business 20 years from now and supporting their product because I'll still be using it. No way do I pay that much for something and end up scrapping it or selling it for a pittance just because it's old.
Rasterops sucked, though, because when they were dying and no longer making video cards but still supporting their old ones they were charging a ton of money for drivers and software so if you were looking for a used graphics accelerator back then you avoided Rasterops cards like the plague because even if you got the card for free, you'd be paying through the nose if you needed drivers or software.
Apple IIe IIc IIGS. Mac 128/512k->Plus 2xPlus SE. Dismantled IIci LC580 6320. Frankenmac Q700/IIvx, 631CD+040, 7500. 6100/60AV /66DOS 6116CD. 6500 7600 9500 G4DA533 G3iMac700 PB150x2 1400
User avatar
Quadraman
Postby Unknown_K » 19 Mar 2010, 07:08
You pay a mint for bleeding edge equipment (still do), and it gets old fast.
Rasterops made some nice cards in the early days of Nubus, they were also one of the first with add-on cards for acceleration so you didn't have to toss the old one out. I think Truevision which made very good video capture cards was purchased by Rasterops very early in its life and did well under them. My understanding is Rasterops charged $75 or something like that for drivers making it uneconomical to purchase (by then obsolete) Nubus cards. I think they sold off the inventory and files to a third party who tried to make a living with support, hence the $$$ fees. It took me a while to find OS 6 drivers for Rasterops cards, but they work well. I could be wrong but I think Rasterops cards (at least the video editing ones) were cheaper then anything Radius and Supermac sold around the same time.
User avatar
Unknown_K
Postby madmax_2069 » 31 May 2010, 05:01
my god, $3500 back in the 90's would almost be enough to buy a pimped Mac Pro today.
The price of a top end video card today is pocket change compared to the price of that card back then.
Yes i know its a old thread
Digital Audio, Yikes, Beige G3 AIO, P 475, Newton MP 2100, Apple IIgs, HP D530 SFF, wyse winterm 3360SE
http://www.Apple2online.com
User avatar
madmax_2069
Next
Return to Peripherals
Who is online
Users browsing this forum: No registered users and 3 guests
