create/emulate SCSI drive using mini Vmac?
Postby giolicious » 29 Nov 2011, 03:30
So how do I create/emulate a SCSI hard drive in miniVmac?
"Everything should be made as simple as possible, but not simpler." - Albert Einsten
User avatar
giolicious
Re: create/emulate SCSI drive using mini Vmac?
Postby theos911 » 29 Nov 2011, 11:47
You need to create a large[r] disk image. This will give you and *effective* hard drive.
68k: Duo 230, 270c, 280c, DuoDock II, DuoDock Plus, Apple Minidock, Newertech Netdock & Ultradock 16sce, 540c, 190
PPC: 2300c, 5300ce, Performa 6500, Wallstreet II 300, B&W Powermac G3 500, iMac G3 700
PRAM? When in doubt, Pull it out!
theos911
Postby 24bit » 29 Nov 2011, 12:24
Correct me if I´m wrong, but I dont think MiniVMac was meant to make use of real SCSI drives.
FusionPC, SoftMac and BasiliskII (some versions) could address Mac SCSI volumes on a PC host,
if that is what you are after.
Still running: 7100/80 and iMac Bondi blue with a few SCSI peripherals.
24bit
Postby bigmessowires » 29 Nov 2011, 17:15
True. The large disks in Mini vMac are actually implemented as super-sized floppies with a custom floppy driver. There is no SCSI emulation as far as I've seen from looking at the code.
User avatar
bigmessowires
Return to Software
Who is online
Users browsing this forum: No registered users and 1 guest
