duanearnett wrote:I'm new to most of this and to this forum also, but is it possible to get BasiliskII to talk to a System 7.0 SE over ethernet?
PowerPup wrote:Basically what you do is install a custom made protocol driver to you windows ethernet card.
porter wrote:PowerPup wrote:Basically what you do is install a custom made protocol driver to you windows ethernet card.
I presumed he was running BasiliskII on the MacOSX box.
Oh yeah! I forgot it was for mac too.
Well, I'm sure there is a virtual driver or something for Mac OS X. Not sure, Have to check that one out myself too.
PowerPup wrote:but yes it can work.
Mac128 wrote:The problem is that Basilisk II & SheepShaver only use the host OS X's AFP drivers.
#/!bin/bash
sudo *Replace with location of Basilisk II folder*/BasiliskII.app/Contents/MacOS/BasiliskII & sleep 5
sudo ifconfig tap0 *Replace with an unused IP of your network* netmask 255.255.255.0
echo "Ifconfig Started!"
PowerPup wrote:I tried it out using Basilisk II running Mac OS 7.5.3, and successfully connected to my PowerBook G3 running Mac OS 9.2.2.
Mac128 wrote:PowerPup wrote:I tried it out using Basilisk II running Mac OS 7.5.3, and successfully connected to my PowerBook G3 running Mac OS 9.2.2.
OK, but what version of OS X? 9.2.2 will easily connect with everything up to Leopard. Snow Leopard breaks it.
Users browsing this forum: No registered users and 1 guest
