iMac G4 minimum OS?
Re: iMac G4 minimum OS?
Postby techknight » 15 Jun 2012, 03:58
10.2.3, this explains why it wont see my retail 10.2.0 disk.
ok that answers everything then ;-)
Main PC: Intel core I7 920, MSI x58 platinum, Radeon4850
PB: tibook G4, ibook G4, Lombard, 160, 165, 180, Duo 2300x2, Duo 270c x2, 520cPPC, 3400c, 1400c
Desktop: G3AIO, 5260/100 x2, SE, SE/30, 512k, plus, LCIII, 7100, iMac G5 iSight, 6400/225
techknight
Postby firebottle » 20 Jun 2012, 13:33
spiceyokooko wrote:Apple made three imac G4's with the PowerMac4,2 identifier -
imac G4 800 - M9105LL/A - NVIDIA GeForce2 MX - 15" TFT - Pre-Installed MacOS: X 10.2.3
I think just got one of these... firmware is 4.5.0f4
I tried booting a custom Mac Utilities CD with Mac OS ROM 10.2.1 on it. It loads the file but won't start the system.
Nor will it recognize any Mac OS 9 system folder as bootable in the Mac OS X startup disk control panel.
Is ROM version 9.8.1 (from a Mac Test Pro CD) the only one that will boot OS 9 on this model? Anybody out there have this?
It's unfair that it can't boot Mac OS 9, since it's the same hardware as the ones that can.
firebottle
Postby LCGuy » 20 Jun 2012, 13:44
12" AlBook came out in January 2003 - Apple announced, from memory, months before that all Jan/2003 onwards Macs would only run OS X natively.
Also, you won't find any files from a MacTest Pro disc on here - those files aren't meant to be distributed to the general public, and as such, linking to them is against the rules of this forum :)
"Bite off more than you can chew and then chew like all Hell" - Peter Brock
User avatar
LCGuy
LC Doctor/Hot Rodder
Postby kem554991 » 03 Jul 2012, 20:53
As far as OS 9 goes, I strongly suspect that if your iMac IS OS 9 compatible, you would need a system specific restore disk. My PowerMac G4 MDD has the same problem. It won't even recognize a retail disc for either 9.1 or 9.2.2 (not sure exactly which one I have).I think almost all of the iMac G4's are OS 9 compatible in some way, shape, or form. I know for a fact that my MDD was the absolute last OS 9 compatible Mac, and it was made in 2004.
iMac G3 Blue Dalmatian/PowerBook 1400cs/Performa 638CD/PowerMac G4 MDD/Mac SE/iPod Nano 2nd Gen/iPod Nano 3rd Gen/iPod Shuffle 5th Gen/iPad 1/Black 2007 MacBook 2.16GHz C2D/
User avatar
kem554991
Postby spiceyokooko » 03 Jul 2012, 21:13
You mean, it was the last desktop Macintosh that Apple made that could boot natively into OS 9! I have the last laptop they made that can boot natively into OS 9 and that was discontinued in September 2003, the 1Ghz G4 Titanium Powerbook.
It wasn't the last machine compatible with OS 9 as many after that can run OS 9 Classic under OS X 10.4.11 or lower.
Pedantic I know, but an important distinction.
Simplicity is the ultimate sophistication...Steve Jobs
User avatar
spiceyokooko
Previous
Return to G3/G4/G5 Power Mac, iMac & eMac
Who is online
Users browsing this forum: No registered users and 2 guests
cron
