Dark screen Restart
Dark screen Restart
Postby 24bit » 15 Oct 2011, 18:15
My Bondi blue Rev. A does not restart properly. The disk is spinning up and sounds like loading the OS,
the Power button is green, but the sreen remains dark.
With Shutdown and cold start the Mac boots like it should - with monitor in use.
Do you have ideas how I could cure that?
Still running: 7100/80 and iMac Bondi blue with a few SCSI peripherals.
24bit
Re: Dark screen Restart
Postby phreakout » 16 Oct 2011, 04:32
It's possible that the Power Analog Video (P.A.V.) board might need replacing. This is a common problem with all the iMac G3 lines, "Molar" Power Mac G3 All-In-One and eMac models. You can find used good replacements on eBay and Craigslist. A lot more cheaper than they were in 2004; then about $300-$400, now about $25-$30 each.
73s de Phreakout. :rambo:
Walking down the street,
The leaves crunch beneath my feet,
Hey, look! An SE!
"Can't you just blow up a couple of PCs to keep the Mac God happy?" - jsarchibald
User avatar
phreakout
Postby 24bit » 16 Oct 2011, 10:45
Thanks for pointing to the PAV!
What puzzles me, when I exchange the iMac "drawer" from a Rev.A to a Rev.B that combo restarts all right.
Maybe I could move the Rev.A logic board into a PC enclosement and connect an old Mac monitor, if the mobo is good.
For replacements, you are a lot luckier in the US than in good old Europe.
24bit
Postby mcdermd » 17 Oct 2011, 21:43
Long ago (2003?) I got a free slot-loader that wouldn't start with a dead PRAM battery. The power light would come on and the drive would spin but no "bong" and no boot. As I recall removing the battery (or replacing) allowed it to boot again.
Classic: Too many to list. See http://www.applefool.com for details.
Modern: 21.5" iMac 3.06GHz Core i3, 15" MacBook Pro 2.4 GHz C2D, 13" MacBook 2.1GHz C2D, XServe Dual 2.0GHz G5
User avatar
mcdermd
Postby 24bit » 17 Oct 2011, 23:11
Yes, the PRAM battery is the usual suspect. I checked it already - 3.65V on board, that should do.
The iMac bongs and boots - but the monitor will only power up from cold start as mains have been disconnected beforehand.
Guess I´ll look for a used PC enclosure next summer on some farmers markets.
Already found a AOC TFT (for Win7 box) and a Canon LIDE (for Hackintosh) for 10€ each.
24bit
Becoming worse
Postby 24bit » 21 Oct 2011, 18:33
My Bondi´s display right now makes unfamiliar clicks, accompanied with some kind of flicker, similar to the de-gauss feature known from some Trinitrons.
I presume this tells me it will fail soon. :-(
Do you think so too?
24bit
Postby bibilit » 21 Oct 2011, 19:56
PAV is probably starting to go
Classic, SE & IIsi 25mhz(RasterOps video)
PBook Wallstreet & 5300 cs
Ibook Clams
Imac G3 slot-in, Bondi and G4
PMac G4 sawtooth, QS & Yikes!, Cube,G3/366 beige (running Mac OS 10.3), 7600/120 (G4)
User avatar
bibilit
Postby phreakout » 22 Oct 2011, 03:50
I'll see if I can dig up the Service Manual PDF for the Rev. A and Rev. B iMacs. It should provide some steps on checking voltages to narrow down which part is faulty. But it sounds to me like a bad PAV board. Again, quite a common problem for All-In-One Macs like that.
Hey, look! An SE!
User avatar
phreakout
Postby 24bit » 22 Oct 2011, 14:51
I connected a old Siemens TFT to the Bondi and that solved the startup issue.
This it how it looks like: http://www.multiupload.com/2DRANFODCN
Now I got two iMac "drawers",one almost dead iMac CRT and some random PC stuff, psu, pATA drives and other crap.
Is it a good idea to save the iMacs psu or wont that one work as standalone?
24bit
Postby 24bit » 24 Oct 2011, 16:23
Thanks for your attention comrades, 13 members cared for downloading the rather mediocre PEBL photo. :-)
Umited States: 6, Germany: 4, France: 2, Canada: 1.
Off topic: Would someone like to recommend a reasonable free picture storage place for linking?
24bit
Postby Cory5412 » 25 Oct 2011, 13:55
You can actually attach a photo directly to the forum software, and display the image inline on the page.
Also, you can use tinypic, photobucket, flickr, google picasa, for picture hosting.
Cory5412
General
Postby 24bit » 25 Oct 2011, 17:53
Thanks again, I did not see it was that simple!
I gave Photobucket a try and there´s a similar picture like the one included,
must have appartments for millionaires neighbouring the Hamburg Philharmony.
http://s1193.photobucket.com/albums/aa349/goodguess/
24bit
Return to G3/G4/G5 Power Mac, iMac & eMac
Who is online
Users browsing this forum: No registered users and 1 guest
