PM 7600 video card...
Postby BGoins12 » 19 May 2012, 14:00
2.5 i5 Mac Mini (Late '12), Dual 1.25 MDD, 1.42 eMac, 5500/275, 7600/120, 8500/120, 7100/80AV, 6100/66, LCII (w/LCIII Board), PB 520, a few PCs, and a 8GB Nook Tablet. More in my link --------->
User avatar
BGoins12
Re: PM 7600 video card...
Postby Trash80toHP_Mini » 19 May 2012, 14:16
Always check for driver availability. I've got at least one (dual head in my case) PCI VidCard for which the drivers are unobtanium. The manufacturer won't provide the because they're Mac specific and referred me to Apple, which of course, was a fruitless effort.
There's one evil mfr. out there who wants an absurd amount of money for the drivers for VidCards manufactured 20 years ago. >:(<
jt [8]
Trash Hauler: call sign: eight-ball
C.O. AC130H SpecOps 68kMLAAF
User avatar
Trash80toHP_Mini
NIGHT STALKER
Postby waynestewart » 19 May 2012, 14:33
The Ati Rage 128 is the standard video card that was used in the B&W G3. I often use those in older PCI Macs as a cheap upgrade.
Computers I have at least 1 of: 128k, 512k, 512ke, Plus, SE, SE/30, Classic, Color Classic, Mac II, IIfx, LC, IIci, Quadras 700, 800, 840AV, 900, PM6100, 6150, 8100, 6500, 7300, 8500, 9150, 9500, 8600, 9600, Beige G3 DT, MT, Server & AIO, B&W G3, Tray loading iMac, Slot loading iMac, eMac, G4 DA, Quicksilver
Mac Portable, Powerbooks: 100,140,145,145B, 160,170,180,190, 520C, 5300,Wallstreet, MacBook Pro
Apple III, Apple II: II, II+, IIe, IIc, IIc+, IIgs
waynestewart
Postby BGoins12 » 19 May 2012, 14:35
I think I'll go with the standard ATI then. I fear that the drivers for the other are in fact made of unobtanium.
User avatar
BGoins12
Postby Trash80toHP_Mini » 19 May 2012, 14:59
The standard Rage Card in my DA, that everyone belittled as being MEH, runs both my 60Hz only, 22" HP 1080p LCD @ 24bit and my 20" MultiSync Dell 1600 x 1200 LCD @ 24bit just fine and dandy. Maybe you'll be as lucky with the PCI version as well.
I'll be expecting a full report after you snag that one . . . :b&w:
User avatar
Trash80toHP_Mini
NIGHT STALKER
Postby Trash80toHP_Mini » 19 May 2012, 15:17
waynestewart wrote:I often use those in older PCI Macs as a cheap upgrade.
. . . unless, of course, you can confirm such performance now! IIRC, the AGP card in my comatose DA is also the Rage 128.
jt [8]
User avatar
Trash80toHP_Mini
NIGHT STALKER
Postby beachycove » 19 May 2012, 15:55
Of the two, the ATI card is the newer and the more capable for most purposes, but both ixmicro and ATI drivers are readily available. They might well be in system software, in fact, as both lines were installed in Apple products from the factory.
ATI drivers will be easier to get, however, as ixmicro is defunct.
User avatar
beachycove
Postby ClassicHasClass » 19 May 2012, 17:44
I use the Rage Orion in my 7300, which is a Mac-specific Rage 128. Paired with a Sonnet 500MHz G3 (I have a 1GHz G3 ready to go), it is good enough to play Voyager Elite Force and Quake III Arena at reasonable resolutions. The only game it stutters with a bit is Unreal and Unreal Tournament, probably because of the reflections.
User avatar
ClassicHasClass
Postby Unknown_K » 19 May 2012, 21:22
Rage 128 PCI are probably the cheapest and easiet to find for PCI Powermacs. Built in video is ok for most things (max out VRAM for more color depth). If you just run OS 7 and want something out of the oridinary you can get a Radius ThunderPower 30/1920 PCI card or an IXMicro Ultimate Rez.
Favorites: big box Mac IIs, 950, 800's
Wanted: Anything Nubus, Video capture and editing hardware and software for 68k mac. Original software including A/UX.
Looking for 9150, Mac II, Color classic, 840av motherboard, and Nubus cards.
User avatar
Unknown_K
Postby waynestewart » 20 May 2012, 03:33
Trash80toHP_Mini wrote:. . . unless, of course, you can confirm such performance now! IIRC, the AGP card in my comatose DA is also the Rage 128.
They made a PCI model as well as an AGP model. The PCI one worked better in the 66 mhz B&W video slot but also worked in a 33 mhz slot. There was a DVD decoder card that attached to the PCI version but it only seemed to work for me with the card in a 66mhz slot. The PCI Rage 128 came in two different speeds. The one with the heat sink being the faster.
I lucked into a couple dozen B&Ws with bad motherboards a few years ago. That let me upgrade the video in most of my PCI Macs. The processors went into beige G3s and a couple of ZIF carriers for the 76,86,9600s. Also scored a couple of the Rage 128 AV cards in the batch.
I've used the Rage 128 card in 7600,8600,9600, 6500, Beige G3s. I do use a couple of ATI Radion and a 9200 where I need a card with DVI output. Did have a Rage 128 in a 9600 driving a 27" HP monitor until I tried plugging My IIgs into it and blew the VGA circuit.
waynestewart
Postby ClassicHasClass » 20 May 2012, 15:17
The DVD decoder card won't work in anything lower than a G3 (trust me, I've tried).
I should parenthetically mention: some people love Radeon PCI cards in their system. These are decent cards and on paper will be faster than the Rage 128, but they have three issues: 1) Radeon gets starved for data over the PCI bus as opposed to AGP more than the earlier Rage chipsets did, negating a lot of their performance improvements 2) they can be quite a bit more expensive, since they are less common and 3) they have weird compatibility glitches with some games, such as bad polygon models in Shogo and Quake II, and not all of the affected titles have patches available. If you can get one cheap and know that your software will work, it's a good option, but the R128 cards are not that much slower in practice, more compatible and more easily available for less cash.
User avatar
ClassicHasClass
Postby Unknown_K » 20 May 2012, 15:32
I have a couple of Mac Radeon PCI models (original and 7000) in B&W G3's where they run at 66mhz (same speed as 2x AGP), they do ok. The Rage 128's that were in the B&W just got moved down to the PCI powermacs.
You do need to figure out if you will be gaming or just want snapier video, and what OS you will be using from 7.5.5 to 9.2 or OSX (not recomended).
User avatar
Unknown_K
Postby BGoins12 » 20 May 2012, 17:22
I've decided to get a Radeon 7000 from a member on here. It's got a 300MHz G3 card installed, so it's gonna have 9.2 on it.
User avatar
BGoins12
Postby Trash80toHP_Mini » 20 May 2012, 21:37
8-) i SUST BOUGHT THE rAGE 128 IN YOUR LINK! :approve:
jt [8]
User avatar
Trash80toHP_Mini
NIGHT STALKER
Return to PCI Power Mac & Performa
Who is online
Users browsing this forum: No registered users and 2 guests
