Best way to test a L2 cache module?
Postby protocol7 » 11 Feb 2011, 23:51
An article I found on Accelerate Your Mac recommended using DayStar's nPower Control for testing memory so I ran a 30 minute extended cycle with that. It passed without errors. But I'm having a weird corruption bug on my 7500 with a 256k L2 cache installed. If I try to mount a disk image in Disk Copy with verify checksum enabled, it will fail if the L2 cache is installed. With the cache removed it passes.
The Orchard: 7500/100 - B&W G3 (x2) - G4 Gigabit Ethernet - iBook G3/500 12" (Dual-USB) - Black MacBook 2,1
User avatar
protocol7
Re: Best way to test a L2 cache module?
Postby beachycove » 16 Feb 2011, 02:49
Sorry to hear this. They can be a little flaky for some reason.
Could it be a software glitch? Does anything else freeze up?
User avatar
beachycove
Postby protocol7 » 16 Feb 2011, 03:16
I don't know if it was only affecting CD transfers, but in addition to causing DiskCopy checksums to fail, it also stopped Mac OS 8 from installing from CD (it failed part-way into the Mac OS install with an error). It took a while to narrow it down to the L2 cache as I was testing all the new stuff.
The thing is, I have a cache module for my 5400 which also misbehaves if it's installed. I could never figure out why. So I have cache modules for both of my OldWorld PowerMacs and neither are currently in use.
If the memory test passes the cache module then what else could be at play? Is there any voodoo involved in getting them to work OK?
User avatar
protocol7
Postby beachycove » 16 Feb 2011, 03:26
It is possible, I suppose, that the cache chip is not fast enough for the processor (150MHz 604?). If it was originally rated for a 120MHz processor, for example, it could be marginal.
There were certainly reports years ago of cache chips causing problems—in fact, problems galore with dual 604e cards.
User avatar
beachycove
Return to PCI Power Mac & Performa
Who is online
Users browsing this forum: No registered users and 1 guest
