Run Mac OS 9 on a PM 6100?
Re: Run Mac OS 9 on a PM 6100?
Postby Dennis Nedry » 25 Apr 2012, 07:30
You could hook a regular DVD player up to an S-video input of an AV card in the 6100.
Dennis Nedry's 68kMLA Wiki Userpage, including my extensive Mac collection.
Dennis Nedry was an awesome Mac hacker, but I hack Macs in his name to preserve, not to destroy.
User avatar
Dennis Nedry
Postby ClassicHasClass » 25 Apr 2012, 13:33
I agree that's the most practical way. That's how I "played DVDs" on my IIci (using a Video Spigot, which should work with the 6100 too if you don't have an AV card). The only downside to that you should try to find a DVD player that is ... er ... flexible with Macrovision or it will screw around with the automatic gain control on the card and give you a distorted image. I have a region free I "imported" from Taiwan for this purpose that doesn't even implement the Macrovision circuit, let alone RCE, and this works well. It plays both NTSC and PAL as a bonus.
It's a shame you really have to go grey-area to get this totally legal application to work. This is another reason I stick with upscaled DVDs instead of Blu-Ray -- Blu-Ray is just another means to ensure you don't actually own what you buy, and upscaled DVD is "good enough" with an HDMI connection and a good upscaler, like a Sony player.
User avatar
ClassicHasClass
Postby mcdermd » 25 Apr 2012, 17:29
I disagree. Upscaling may look the same (or "good enough") to your eyes but it looks pretty blurred to mine, even when compared to HD streaming content.
Classic: Too many to list. See http://www.applefool.com for details.
Modern: 21.5" iMac 3.06GHz Core i3, 15" MacBook Pro 2.4 GHz C2D, 13" MacBook 2.1GHz C2D, XServe Dual 2.0GHz G5
User avatar
mcdermd
Postby ClassicHasClass » 26 Apr 2012, 00:15
Like everything, it's a matter of taste, of course. But there are crappy upscalers and there are good upscalers, and a good upscaler makes good output. (I didn't say indistinguishable. :P )
But that's orthogonal to the OP.
User avatar
ClassicHasClass
Postby Bunsen » 30 Apr 2012, 16:35
Theretrogamingroom wrote:Any idea if I could do anything with the NuBus Slot?
Er ... Put a Nubus card in it? Not really worth it, IMO, because a/ you can only use 7" cards, without severe case surgery, and b/ you can't mount a G3
the only problem would be a decoder card? Sounds like a hack/mod begging to be made!
Uh, no. You still have to find some way of getting data off the disk, fast enough, to the decoder card, and then back to the video controller in some form recognised by both the hardware *and* the OS, and find some way of driving it from the OS as well. In short, not impossible, per se, but also not gonna happen, unless you're a very bored qualified EE with classic Mac OS coding experience.
Use a faster machine to transcode files to VCD format if you really want movies on your 6100.
have you searched? Seeks: Nubus PDS DSP PB170 Newton; TRS-80 III/4; CBM BBC SX-64 CX5M Likes: 8bit luggable palmtop terminal NC tablet audio MIDI analog FM drum synth steam&dieselpunk; 1930-1980 lab/comm/mil Score! NC100 PB190 Q950 IIe-PDS
User avatar
Bunsen
Witchfinder-General
Postby Nathan » 23 Apr 2013, 18:31
Totally necro'ing this for amusement..
There's a dvd decoder card that goes in the PCMCIA slot for the powerbook g3 isn't there (like this --> http://store.mcetech.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=DVDMPG2&Category_Code=_pbg398&Product_Count=1)? Not that adding a pcmcia card would be trivial or anything, but that seems like one plausible direction to take. Assuming you fit the qualifications below, some kind of wacky nubus pcmcia controller might allow you to use that. I expect you'd seem some kind of special software to make that work... Or, maybe this -> http://micha.freeshell.org/pcmcia_drive/index.php could be repurposed for that...
I hate theoretical possibilities... They are always incredibly unlikely to be doable, work out, especially not for the average person.
PPC: PowerMac G4 800 DP QS, Bondi iMac G3 333MHz (Upgraded from 233MHz) -- 256MB, Performa 6100/66 -- 72MB RAM - hd now dead :(
68k: Macintosh LC II -- 12MB RAM
Older: Apple IIe Enhanced -- 128KB RAM, Newton eMate 300 w/memory enhancement -- 4MB RAM
Nathan
Previous
Return to NuBus Power Mac, LC & Performa
Who is online
Users browsing this forum: Google [Bot] and 2 guests
