Sonnet G3/250 for a PM6100/66
Postby highlandcattle » 20 Mar 2012, 21:50
Hiya all,
Sometime ago I bought a Sonnet G3 from Strimkind on here, but I don't have the actual software to make it work. On these forums I found Sonnet Crescendo EnablerV31. But it doesn't work, it freezes upon loading the extension. The Powermac works fine with extensions off. I also googled it and sadly it seems that I need an older version, but the Sonnet homepage turns up blank(all accelerator drivers seem to have been removed :(0 .Anybody know where I can get older drivers?
Also can I use these cards with System 7.6.1 or do I need to use 8 or9?
User avatar
highlandcattle
Re: Sonnet G3/250 for a PM6100/66
Postby ClassicHasClass » 21 Mar 2012, 04:21
Odd, v3.1 should be universal. What version do you need? I can see if I have it around.
User avatar
ClassicHasClass
Postby highlandcattle » 21 Mar 2012, 20:55
I can't seem to find the posts on google which talked about the versions of drivers. But If you have any older versions I would be aces if you could upload them so I can check them out.
Btw do you know if you can use 7.6.1 or do I really need to use 8 or 9.
Thnaks so much already!
User avatar
highlandcattle
Postby ClassicHasClass » 22 Mar 2012, 01:34
I don't have any on the file server other than 3.1, but I have some floppies around somewhere that should have them.
User avatar
ClassicHasClass
Return to NuBus Power Mac, LC & Performa
Who is online
Users browsing this forum: No registered users and 1 guest
