Performa 6200CD found - any maintenance?
Postby gubbish » 08 Apr 2011, 02:37
Hi All,
I recently got a Performa 6200CD that someone was giving away on freecycle.
Other than needing a new hard drive (former owner removed theirs), it seems to work fine.
Is there any important maintenance that would need to be done on this computer? Batteries, capacitors, etc?
Seems to work fine now, but wanted to know if I should be removing any internal batteries or anything like that. Thanks!
gubbish
Re: Performa 6200CD found - any maintenance?
Postby Concorde1993 » 08 Apr 2011, 09:04
gubbish wrote:but wanted to know if I should be removing any internal batteries
You should always remove the PRAM battery upon receiving an old modular computer just to avoid potential leaks, etc., which could destroy the motherboard.
Probably should check the caps too to see if any are bulging or if anything is out of the ordinary.
Vintage Macs:88 SE SuperDrive, 87 Plus (was a 512ke), 512K, Plus, IW II (2x), 96 5215CD, LW 300, SW 1500, SW 2200 (2x), MS 17, SC 20 HD, 800k ED & eMate
Other: Amiga 2000HD, 81 VIC-20, 88 Commodore PC 10-III, 84 Commodore 1701, 81 Datacasette
User avatar
Concorde1993
Postby LC_575 » 28 Jun 2011, 03:33
Caps are an unlikely problem with computers that new. Usually the "black box" (as I can them) PRAM batteries that the mid-90's Performas use don't leak. However, by now it's most certainly dead.
If you want to make a quick PRAM batt, just cut off the wire + connector from the PRAM batt and then connect the ends to 3 AA or AAA batteries in series (red wire goes to positive end). Wrap it in some tape, plug it in and there you go!
The Performa 6200 is one of those 5xxx/6xxx models that may have a faulty CPU or Cache, which can cause random system freezing. There's an Apple utility that can check if your system is affected:
http://support.apple.com/kb/TA35668?viewlocale=en_US
Lost all the Macs to Hurricane Sandy.
The '90's didn't end with New Year's 2000. They ended with the release of 9.2.2.
User avatar
LC_575
Return to NuBus Power Mac, LC & Performa
Who is online
Users browsing this forum: No registered users and 1 guest
