by wally » 03 May 2008, 16:56
Look for PB500DuoModem.sit at the new hotline techfury90 set up (thanks!), at ueberlandowiki.net (currently in the uploads area, probably should be relocated to Drivers). If you have the software for using external modems working (recommended as a first step), adding this will allow you to connect with the original Global Village internal modem, at speeds up to 19.2kbps.
SE/30, PB540c, PB1400c, PMG3DT, PBG3-400 Firewire
