2.5" SCSI SSD Project
Re: 2.5" SCSI SSD Project
Postby Trash80toHP_Mini » 21 Mar 2011, 01:55
techknight wrote:I just sent the board off to have fabbed. setup fees and all, it ran about 72 dollars. OUCH.
But hey, its a prototype, and its cheaper than what i would have paid for a double-board, 4 layer sandwhich.
Congratulations, you've got your proof of concept prototype/debugging design out the door and off to the Fab Lab in a form factor that's more workable for assembly, for testing and still in a salable package!
EXCELLENT work, kiddo! :approve:
What's the turn around time and expected assembly completion? :?:
Double that and use a correction factor of three for the software coding/debugging estimate! ;)
jt [8]
Trash Hauler: call sign: eight-ball
C.O. AC130H SpecOps 68kMLAAF
User avatar
Trash80toHP_Mini
NIGHT STALKER
Postby techknight » 21 Mar 2011, 02:41
Depends on when the fab house sends off the panel.
I am using SparkFun's service, which is the cheapest for single board runs. Because they put a bunch of submitted designs on a single panel for fab, its cheaper per person this way.
So i gotta wait for the panel to fill, which doesnt take long, and then get sent off. 3 weeks max, 1 week min.
Also i got the parts i didnt have on hand, ordered tonight. Another $50 bucks there.
The transceivers are 26 bucks a peice from digikey 8-O
So i went straight over to TI and got 2 samples. heck with 26 a piece until i know if its gonna work.
So, regardless, if this works out, i am gonna have to sell it off just to fund the 2.5" project, which was my ultimate goal. I only have limited funds available for this hobby stuff, and i damn near ran out. lol.
Also i ordered enough parts to build 10 of them. so a total of $50 in parts, approx 10 bucks a board.
this is MINUS the transceivers, and AVRs/Crystals, as i have that stuff kicking around.
I did end up making a couple of errors on the board, but hey, i can fix that though. no routing errors, just forgetting "resistors" errors. one on the RESET signals, and another one on the LOF signal to the CF slot.
Main PC: Intel core I7 920, MSI x58 platinum, Radeon4850
PB: tibook G4, ibook G4, Lombard, 160, 165, 180, Duo 2300x2, Duo 270c x2, 520cPPC, 3400c, 1400c
Desktop: G3AIO, 5260/100 x2, SE, SE/30, 512k, plus, LCIII, 7100, iMac G5 iSight, 6400/225
techknight
Postby Trash80toHP_Mini » 21 Mar 2011, 03:31
That sounds a lot like the early days of VSLI, boards (ICs) were ganged up into one panel (die) and run the same way this service is doing it now.
My dad had all the VLSI Texts Laying around the house along with Fortran, Cobol and a bunch of other programming Texts, a hunk of CORE Memory, PunchCards and "Think" plaques.
I loved the VLSI Texts . . . as art books! ::)
Keep us posted, I'm sure a limited run of your corrected Prototype will fund the next step . . .
. . . and allow you to hold onto your first prototype! ;)
jt [8]
User avatar
Trash80toHP_Mini
NIGHT STALKER
Postby techknight » 21 Mar 2011, 04:21
Ya. im worried about speeds as well. Using 16mhz clock source for 2 8-bit micros are bottlenecks.
however, its expected to get roughly 1.5 to 3mbps, or 150 to 300KBytes/s depending on the compact flash used, etc...
and this also varies HEAVILY on the cross-talk. lol.
Worse comes to worse, i can use that conductive "pen" silver oxide, and coat the entire set of traces with it. and draw it over to a ground via.
As far as CORE memory, that stuff is unique how it works. I still cant quite understand how it works. I restored a broken down seeburg jukebox that used the CORE memory as its TORMAT selection device. same concept.
techknight
Postby Trash80toHP_Mini » 21 Mar 2011, 12:36
How about laying down a strip of copper or aluminum foil on an oversized pad of (non-conductive?) varnish, letting that dry and then using the conductive pen (or solder a piece of jumper wire you've already got to it for your connection [;)] ) and then varnishing it again for protection?
Digital Decoupage!
I'd use lemon gold leaf or variegated gold leaf, but I'm a crazy sign painter who apprenticed BG (before Gerber)/BC (before computers) who minored in Fine Art, about 1/2 of it screen printing (in printmaking classes 1-3) & classic training in most other disciplines. So you never know what kind of $*#% I'll come up with.
_____________________________________________
I like the notion of using a small strip of PCB laid down across something like your bus section on the debugged rev of your 3.5" form factor design. It'd be a salable, limited edition run of collectible 3.5" ProtoBoards.
To maximize initial prepaid orders, add in the (estimated/amortized) cost of a free 2.5" final production board and maybe a 10% discount on any future 2.5" production board orders by your "investors." Then you'll have the $ to defray your development costs to date and the development capital for the 3.5" limited edition up front.
You'll have another "buy in point" for the collectible limited edition version of the 2.5" board for those comrades who'd want to wait for your proof of concept success before sending you $.
Give your initial "investors" a big discount (and another free 2.5" final production board based again on the the (estimated/amortized) cost of their orders for the 2.5" collectible limited edition board.
For development boards & limited edition revisions you'd:
____ add the daughtercard section(s) to your main design along the most cost effective (short or long) edge.
____ divide it from the main card by a pair of properly spaced trace strips placed as guidelines for scoring/snapping _________ or spaced at the kerf width of a bandsaw or coping saw blade for cutting a more complex shape.
_________ I've got the bandsaw to do the cuts and can advise you as to the proper radii for complex shape turns. [;)]
By doing this for both sides of the bus section of your 2.5" initial prototype would give you:
___ 4 or 6 layers of PCB for the bus section (or the entire board) on your 2.5" design
________ at a minimal 2 sided PCB price increase.
___ 2 layers of solder mask dividing the ground plane from the main board signals for insulation.
___ avoid using headers as board interconnects
___ use bits of wire as your physical and electrical interconnect for signal traces AND ground!
___ another spot for placing ICs for the final 4 layer PCB production boards & simplify trace routing
. . . whatever, it might work out, my brain just shut down and it's time to get ready for work. :-/
jt [8]
User avatar
Trash80toHP_Mini
NIGHT STALKER
Postby trag » 21 Mar 2011, 19:57
I should have posted this link earlier:
http://www.seeedstudio.com/depot/services-c-185.html
Ten pieces of 5cm X 5cm 2 layer board for $20, or ten pieces of 10cm X 10cm for $40.
I didn't realize you were so close to fabrication....
trag
Postby techknight » 22 Mar 2011, 02:16
I dont play around, hehe.
NOW you tell me. WEEEEEEEEEEEEEE
well ill use em for the 2.5" run. Id rather find a cheap 4-layer service, but ill take what i can get.
As far as the "investors" thing, i vowed myself NEVER to do that. i like to do things with the money i have. if it dont work out, it dont work out. i dont end up "oweing" people.
techknight
Postby trag » 22 Mar 2011, 21:06
techknight wrote:well ill use em for the 2.5" run. Id rather find a cheap 4-layer service, but ill take what i can get.
That's the holy grail. I haven't priced them in a while, but the best I've found has been 4-layer proto services from which you get four boards for about $200. Now, the boards can be large, like up to 8" X 10" or some such, but they don't allow repeats in the proto service, so you can't squeeze multiple boards onto one proto.
trag
Postby olePigeon » 23 Mar 2011, 22:14
Have you thought about talking to the guys at ReactiveMicro? They make cards for Apple II computers, maybe they have some advice or can help you with the prototyping, fabrication, or technical problems.
User avatar
olePigeon
Postby techknight » 24 Mar 2011, 01:43
its slowly starting to come together.
I just got my transceivers from TI, and the digikey parts arrived.
techknight
Postby insaneboy » 03 Apr 2011, 15:37
any updates?
insaneboy
Postby techknight » 03 Apr 2011, 22:02
All the parts are in, still waiting for the board to arrive.
Ordered from BatchPCB, and they are slow as dogsnot. STILL processing. Ill never order from them again.
I ordered enough CF sockets to build at least 10 of them.
techknight
Postby techknight » 07 Apr 2011, 00:43
BatchPCB has shipped the board. So its on its way here.
What sucks is in order for me to make changes to my CAD drawings, or etc, i have to do everything ALL over again.
Why? my HDD decided it wanted to take a shit. LOL. ironic. hehe. So i lost everything. gotta start over. :P good thing i didnt start editing/proofing the code. i still have copies of.
techknight
Postby Bunsen » 07 Apr 2011, 01:16
Backups, people.
have you searched? Seeks: Nubus PDS DSP PB170 Newton; TRS-80 III/4; CBM BBC SX-64 CX5M Likes: 8bit luggable palmtop terminal NC tablet audio MIDI analog FM drum synth steam&dieselpunk; 1930-1980 lab/comm/mil Score! NC100 PB190 Q950 IIe-PDS
User avatar
Bunsen
Witchfinder-General
Postby Trash80toHP_Mini » 07 Apr 2011, 02:41
The artwork backed up in this thread should be a pretty good start! :approve:
The new board's gonna be four layer to get it all to fit the form factor, just be sure to keep one two layer board unpopulated for troubleshooting/testing any last minute changes that may not have been posted! [;)]
edit: Did you run Disk Warrior on that (^*%$#*()? HDD! >:(<
BTW, how do you like that PCB Layout Program?
Which OS?
What CPU?
RAM?
General config?
Monitor(s)?
Input device?
etc? :?:
jt [8]
User avatar
Trash80toHP_Mini
NIGHT STALKER
Postby techknight » 08 Apr 2011, 02:57
I am using my main machine. which is an intel core i7 that dual-booted between win7 and hackintosh
My HDD was fully encrypted with truecrypt, because i have/had other sensitive information on it, well DID anyway. I have multiple people that live with me under the same roof, and they dont keep their "prying eyes" out of other peoples personal lives/information. Plus i used to exploit hardware/software flaws in smartcards. AT89SC, 8051, ST7, ST19, etc... but all that crap is now gone, never kept backups for "obvious" reasons. and i retired from messing with that stuff long ago. it was a fun hobby, but i lost interest.
I went to grab the recovery disk that contained the backup of the master keyset, and hash keys, etc... and it had a nice scratch on the data layer. my CDs lay around loosely which is a really bad bad bad habit of mine.
somehow a virus snuck into the bootsector which overwrote the master keys. first time that has EVER happened to me.
techknight
Postby techknight » 08 Apr 2011, 03:04
Software wise, i used freePCB. took awhile to get used to, but its pretty much a slim/cut down version of eagle, and its open-source freeware. still uses all the same concepts, you have to create nets. then it generates ratlines that you can route.
the nets can be put in by hand which is tedious, OR if you have a schematic, the netlist is generated from it. this way you cant make a mistake or forget things. unfortunately i have no "digital" copy of the schematic in any form that freePCB can understand to autocreate nets.
P.S. on a lighter note, i dont have a schematic AT ALL now. lol. gotta redo that. Actually, i may just do it in a format that freePCB can import, itll make board routing go much faster.
techknight
Postby techknight » 09 Apr 2011, 01:34
Boards arrived. They sent me 2, i only ordered 1.
But hey, i am not complaining.
And boy, do they look beutiful. lol. Ill have to take a picture when i get a chance. Its just too bad i have to redo the CAD again. friggen A. PITA.
techknight
Postby MacJunky » 09 Apr 2011, 01:44
Do we get boardpix? :-D
LC 630, P580CD, LC 575, Mac Plus X2, PowerBook 160, PowerBook 150 X2, PowerBook 145
User avatar
MacJunky
Postby techknight » 09 Apr 2011, 21:05
pictures of the board.
techknight
Postby JRL » 10 Apr 2011, 01:23
Very nice! You are an amazing person for taking up this task.
Sorry to hear about the lost CAD drawing though. :(
Plus (MicroMac Performer), SE x2, Classic, LC x3, LC II, LC III, P460, LC 475, LC 575, Color Classic, II, IIci (PowerCache), IIsi x2, 150, 160 x3, 170 x2, 180c, Duo 2300c, 520c x2, 5500, 6360, Duo Dock, 7100, iBook 366, MacBook
User avatar
JRL
Postby techknight » 10 Apr 2011, 02:28
Ya, i got to redo it now.
But regardless, i have to re-do it anyway because i want to try to scale the board back down to 2.5" again.
Once this project is done and over with, i am going to make a replacement modem for the PB1XX series to replace the internal modem with an xBee wireless COMM module. and write some realbasic software to send AT commands to the xBee to configure it for the various network topologies and keys.
so basically you can use it as a wireless "localtalk" setup.
techknight
Postby LCGuy » 10 Apr 2011, 08:35
That is just beautiful. :)
"Bite off more than you can chew and then chew like all Hell" - Peter Brock
User avatar
LCGuy
LC Doctor/Hot Rodder
Postby Byrd » 10 Apr 2011, 12:29
Oh man - that looks great, can't wait to see the PCB populated with chips and working! We're lucky to have you around here, not many projects go through :)
JB
:: Current project Mac: PB1400 resto
User avatar
Byrd
Postby Trash80toHP_Mini » 10 Apr 2011, 13:17
Sounds like a great candidate for having a Duo Modem Connector's Thru-Holes on the opposite side pf the PCB! ;)
<Kojak mode>
Beautiful Boards, Baby!
</Kojak mode>
jt [8]
User avatar
Trash80toHP_Mini
NIGHT STALKER
PreviousNext
Return to 68k PowerBook
Who is online
Users browsing this forum: No registered users and 2 guests
