noidentity wrote:This site requires turning off stylesheets when viewed with Classilla 9.0 (View->Use Style->None), each time the link is opened in a fresh window/tab. It's somewhat ironic, considering the target audience of this site.
noidentity wrote:It's somewhat ironic, considering the target audience of this site.
John8520 wrote:noidentity wrote:It's somewhat ironic, considering the target audience of this site.
Just because we use this site to discuss old macs it doesn't mean we have to be able to work on this forum with said old macs. I, for one, have absolutely not interest in browsing the web with my old machines, I like to do with them what was intended, and while they were made to handle HTML/FTP/Gopher they're not particularly well known for processing javascript, CSS, and ajax.
Quadraman wrote:noidentity wrote:This site requires turning off stylesheets when viewed with Classilla 9.0 (View->Use Style->None), each time the link is opened in a fresh window/tab. It's somewhat ironic, considering the target audience of this site.
If you read the Classilla site, they recommend using iCab for sites where you have to use CSS or turn them off in Classilla because the support is not good. Of course, if you're still surfing using Classic, any browser you use is going to have trouble with modern web content.![]()
And most of the target audience of this site also has at least one computer capable of using a reasonably modern browser so it's not really an issue.![]()
ClassicHasClass wrote:Quadraman wrote:noidentity wrote:This site requires turning off stylesheets when viewed with Classilla 9.0 (View->Use Style->None), each time the link is opened in a fresh window/tab. It's somewhat ironic, considering the target audience of this site.
How timely. Tonight I'm posting from my current internal build of the forthcoming Classilla 9.1. And may I say the MLA has never looked better in it. Watch for it coming soon.
Quadraman wrote:ClassicHasClass wrote:Quadraman wrote:noidentity wrote:This site requires turning off stylesheets when viewed with Classilla 9.0 (View->Use Style->None), each time the link is opened in a fresh window/tab. It's somewhat ironic, considering the target audience of this site.
Sounds interesting. Glad to see it is still improving. Every little bit brings it that much closer to the modern era. How's it run under Sheepsaver with 9.0.4? My new Powerbook G4, which is my fastest classic capable machine, came loaded with Leopard so no classic mode for me.
ClassicHasClass wrote:Quadraman wrote:ClassicHasClass wrote:Quadraman wrote:noidentity wrote:This site requires turning off stylesheets when viewed with Classilla 9.0 (View->Use Style->None), each time the link is opened in a fresh window/tab. It's somewhat ironic, considering the target audience of this site.
I don't officially support Sheepshaver, but I am told that it works fine in it. Classilla will run on 8.6 and up (8.5 under duress), so Mac OS 9.0.4 should be no problem.
I don't have an ETA for Classilla 9.1, but it will be "soon." In the meantime, Classilla 9.0.4 does rather better on the MLA if you turn on the experimental renderer (View > Use Experimental Renderer or Cmd-Shift-X). This overrides certain settings in layout with laxer ones. While it makes the site kind of messy, everything should show up and be clickable.
Quadraman wrote:ClassicHasClass wrote:Quadraman wrote:ClassicHasClass wrote:Quadraman wrote:noidentity wrote:![]()
about it, and if he gets
, then I'll just
for awhile, and if he's still
and
, then I'll just
and make up even if he's
or
, and I'll
from then on. Unless he goes all
on me, in which case I'll be
or
. Like,
the heck, man, I'm just trying to be
and stuff. Don't get so
about the deep quoting!Mike Richardson wrote:
macgeek417 wrote:
You should AT LEAST do some basic smoothing. That'd look much better if you ran it through hq4x or something
)Can't we get some sort of list that shows exactly what is being blocked? It is a real pain in the posterior to have no idea what got blocked; preventing you from adding it.(for when adding the site you are on does not help)ClassicHasClass wrote:edit: ignore my stupidity, it helps if I put 68kmla into the NoScript list -- thought I already did that...
Return to General 68kMLA News & Stuff
Users browsing this forum: No registered users and 1 guest
