I think you may have gotten very lucky here. That appears to be pin 30, which is a ground. There are two other grounds on the connector, on pins 10 and 64. 30 and 64 are tied together, at least on the factory SIMM that I tested, so as long as pin 64 is good, you should be fine without pin 30.
